Clamping flat bar stock for flycutter
  • Clamping flat bar stock for flycutter
    I want to put a nice flycutter finish on some .375x2x8" flat bar aluminum. It's too long to put in the vise. How does one clamp this piece so a single continuous run can be made over the surface with a flycutter?
    You need either toe clamps or Tee slot clamps something like this :-
    http://www.nolansupply.com/bysubcate...lse&specs=True
    Cheers
    Bryan
      Just use regular hold-down clamps and stop with the cutter off the
      material and reposition the clamps and start up again. Do it all the
      time with a lathe. Even with the cutter in contact with the work you
      can stop and start without a mark on a lathe so it should be a
      "peice of cake" with the flycutter off the work.
      ...lew...
        Thanks, Bryan.
        What are the pros/cons of toe clamps vs T slot clamps?
        How many clamps would be needed to secure the workpiece described?
          Lew- From my (admittedly limited) experience, any interruption of a flycutting operation is visible in the finish. Am I wrong?
            I guess it "Depends". :-) If the X drive can be stopped same as the
            spindle it should be OK. I'll have to try it next week and see how it looks.
            ...lew...
              Cheers
              Bryan
              Yep... I had some from an auction and never used them until recently. How can those wimpy things possibly hold? LOL... they clamp REALLY well...
                Originally posted by Mensch-Machine
                Thanks, Bryan.
                Cost, those mite bite clamps are very expensive for what they are.
                  Good question, I think Toe Clamps can be used in more situations. T slot clamps are cheaper (and easier to make!).
                  You might get away with one at each end but you proably want a couple in the middle. Depends on what you can fit on your table.
                  The third option migh be to have a second identical vice but that gets expensive for a one off
                  If you are making them yourself have a look at http://homews.co.uk/page108.html
                  Cheers
                  Bryan
                    Expensive? yep.... and not too difficult for a HSM to make once you see them (basically an eccentric center that pushes on a nut body), but these are hardened and ground very nicely for production work.
                    Two vices is often the quickest, and I do that a lot.
                      No, but a few suggestions:
                      *Don't clamp too hard. For a finishing pass with a flycutter, a light pressure is fine. Remember that even though you are clamping TO a flat surface, your clamps may distort the workpiece itself.
                      *Don't stop the spindle with the tool over the workpiece---as in, turn off the motor and let the spindle spin down to 0rpm. Depending on tooling, this can alter your DOC and leave a "groove" in the workpiece.
                      *ADD new clamps before removing old clamps to expose the rest of the surface. I find it tends to balance out most of the distortion if there is any from clamping pressure.
                      *Lastly, just because you see a line, doesn't mean that it is measurable to a significant digit You can finish it out with some scotchbrite or something for a more uniform look.
                        carpet tape
                          2nd on carpet tape.
                            Carpet tape. Now THAT sounds like an inexpensive solution. Thanks!
                            Any problems with residue on the table? Have a specific type or brand to recommend?
                              But.. if your table is as oily as mine, you'll need to use solvent to get a grease-free surface for the tape to stick.
