I'm in the middle of a big job with my CNC lathe and the control quit this morning, blows the on-board fuse repeatedly. It's an old (1996) Denford Smartstep/3 control but has low time on it.
I examined the board and it looks like the device pictured below, a KBU806 rectifier may be fried. The only spot on the board that looks like it's been hot is where it's soldered on by its 4 pins. The solder around those pins has obviously gotten to the melting point and all other pins on the board look slick & shiny.
The question is whether something else caused it to fail or did it just die of old age. I was worried about the big capacitor next to it because the cap is bulged but I posted that question here a while back and some posters said it was probably OK. It's been working fine for almost a year in light use. When checked with an ohmeter, it measures low resistance for a moment, then high. I think that's how you test 'em without a proper tester? Would a fault with that capacitor overload the rectifier? If I could find a place open today (not likely these days) I'd replace both of them. Ya'll eleck-trickal experts have any thoughts?
