Screw Countersink Angles, Cutters
  • Screw Countersink Angles, Cutters
    Can anyone tell from this link the countersink angle of these screws?
    http://www.fastener-express.com/flat...ess-steel.aspx
    How about a recommendation for countersink cutters?
    C'sink Angles
    For inch fasteners the head is 82 degrees, for metric fasteners the head is 90 degrees. There are usually exceptions and specials but this covers the great majority.
      What are 60 degree countersinks typically used for?
      Grizzly doesn't seem to have the same type of cutters for 82 and 90 degree countersinks:
      http://www.grizzly.com/products/90-1...sink-Set/G5729
      http://www.grizzly.com/products/5-pc...-Set-82-/H2995
      Is there a significant difference between the 6 flute and the single cutting point type?
        C'sinks
        They all cut good. The zero flute, the kind with the hole, are less likely to chatter. The 6 flute ones can be run at at slow RPM to keep chatter down. I've never found a need for 60 degree ones.
        90 to 120 RPM works good for all of them.
          I actually don't know where you'd find the need for a 60* countersunk hole unless it is a combined drill/countersink for centers.
          I know 100* and 110* countersinks are sometimes used in the aerospace industry, but the two most common are 82* for imperial and 90* for ISO.
          I've heard that single flute countersinks cut better than multiflute but there has been quite a bit of debate about that. What is important is speed and feeds. You can typically avoid chatter with low speed and high feed.
          I would also like to suggest that you consider getting a high quality set. I've used KEO and generic import countersinks and the import ones were a PITA. They were not ground as well as the KEO and tended to chatter much worse. I own my fair share of import cutting tools, but taps and countersinks are two items that I always try to buy quality.
          See here, for instance:
          http://www.use-enco.com/CGI/INSRIT?P...&PARTPG=INLMK3
            Thanks, I ordered that set from Enco.
