How I Move My Machines Round Single Handedly
  • Kiwi
    It's a what ? and where does the coffee come out
  • JoeLee
    Someone had asked how I put the 2" x 1/2" flat bar under the base of the machine. This is how it's done. A short pry bar and some small blocks of wood of various thicknesses. I can easily tilt the machine with one hand on the bar and position the flat bar under it
    I'm setting it up to move my surface grinder, it's the same base as the T&C grinder in my previous posts except this base has only three feet..... 2 in the front and one in the back (in the center) so I have to use some blocks on the back corners so the bar picks the corner of the base and not off the center foot, all that weight in the center of the bar would shurley bend it.
    JL...................
  • daryl bane
    Yeowza! Very nice
  • JoeLee
    Originally posted by moe1942
    How do you get the machine on the flat bars and is the threaded rod secured with nuts on the bottom??
    It might be a sin to have such a clean machine...
    I use a pry bar to tilt the machine enough to slip the 1/2" flat under the base, thats the nice thing about using 1/2" flat bar is you don't have to tip the base much to slide it under. The flat bar is threaded for the rod, no nuts on the underside, just on the top to lock it and stabilize it.
    JL.................
  • Toolguy
    T&C Grinder
    Looks like you might need a new v belt, but the rest is just plain Tool Porn!!!
  • moe1942
  • Bob Farr
    Originally posted by JoeLee
    *** Here is a picture of the rest of the machine. ***
    It's nice to see such a well care for machine. Thanks for sharing the pictures of your moving-base idea.
    Bob Farr
  • JoeLee
    I threaded the flat bar for the 5/8-11 threaded rod. I didn't run the tap all the way through, just enough for the rod to snug up tightly before comming through the bottom. Then a nut to lock the rod in place and stabilize it.
    I also milled a 1/2" hex at the top of each rod so I could tighten them up into the flat bar.
    The four long pieces are 2" x 2" x .120 wall tube, common stuff.
    The pieces that slip over the 2" are 2 1/4" x .109 telescopic sq. tube. This stuff is made to slip over the 2". It's not real common and not too many places stock it, hard to find. The seam is in the corner of the tube as opposed to the center as most other welded seam sq. tubes are. Also the odd wall thickness of .109 ensures enough clearance for most 2" tubes to fit.
    JL.....................
  • dvo
    where do you get tube that fit inside another?
  • Black Forest
    Did or have you ever used that machine? It looks brand spanking new!
    How do the threaded rods attach to the plates running under the machine to be moved?
  • Flying-Phantom
    So that's what a shop floor looks like.
    Very nice machine.
  • justanengineer
    Very nice Joe!
  • mmc005
    Very nice machine! Nice job on the rig also.
    I use toe jacks and a pallet jack to move mine around by myself.
  • H380
    ohhh My!!
  • JoeLee
    Thanks for all the nice comments....... Here is a picture of the rest of the machine.
