Made in feed and outfeed tables for a table saw. They were 30" x 120" and used contact adhesive. Still together, after 10 years in a solid surface fabrication shop.
Bonding UHMW
It will glue ok with several types of glue if the surface if roughed up and especially if the substrate is non porous. The problem is when there are major temperature changes.Free software for calculating bolt circles and similar: Click Here
Thermal expansion is the new issue. Assuming the UHMW was absolutely bonded to the MDF it is my understanding that the expansion will happen resulting in something bad happening. I am now looking at mechanical fastening that will allow for expansion.
thistothat.com
another site for info on adhesives
The multi-grip is great stuff works on a large assortment of materials. Nothing more than a satisfied userGlen
Assuming the UHMW was absolutely bonded to the MDF it is my understanding that the expansion will happen resulting in something bad happening.Free software for calculating bolt circles and similar: Click Here
Evan speaks of corona treatment.
You can achieve the same effect by kissing the surface of the sheet with the VERY EDGE of a gas flame. Move the torch VERY quickly or you will end up with a melted puddle of very hot plastic."The Administration does not support blowing up planets." --- Finally some SENSIBLE policy from the Gov!
Pretty risky with only .125" material.Free software for calculating bolt circles and similar: Click Here
I'm curious as to the application. Also, I'm questioning the use of the 4x8 sheet- is that the size of the final part or is that the parent material from which many parts are cut?
In the past I've made mold parts from mdf which were destined to go in the oven with a piece of plexiglass on it, or abs or pvc sheet. While I got the results I wanted, the mdf outgassed at heat (under 300F) and that's something you really don't want going up your nostrils. It's pungent, noxious, and a considerable irritant. Who knows- if I was to spawn a child- well who knows if it would be a child or a - thing. That stuff can not be good for you.
Here's an idea though- if the uhmw can work by being attached to the mdf in many small pieces, you can just use small screws. Countersink the heads and drill pilot holes. Use a method like they do for setting tiles- you can buy bags of those little plastic spacers for cheap. Use them to set the grid pattern and screw away. Were it me doing it just as I've described, I'd make a jig to make easy work of cutting the sheet of uh into equal size and shaped pieces, then I'd make a hole drilling pattern and spot drill all the pieces, then I'd set up one cordless drill with a combination countersink/pilot hole/depth stop and a second cordless with a driver for the screws. I'd be making good use of the torque limiter on the drill as well.I seldom do anything within the scope of logical reason and calculated cost/benefit, etc- I'm following my passion-
Here is garland Manufacturing's page on how to glue UHMW. They actually manufacture it and they give specific glue recommendations. None of the lap joint strengths are all that high but they might suffice.
http://www.garlandmfg.com/plastics/bonding.html
I've had problems with UHMW warping when heated as it seemed to allow internal stresses to have their way with the material.
Regards,
Cameron
