I made a super simple box tool
  • I made a super simple box tool
    Last week someone posted that they wanted to make a small box tool. And they did not want to use a mill to do it. Got me thinking and here is what I made. I took a piece of stock and turned one end to .75 dia, then drilled other end .75 dia about an inch or so deep. As only turning down 1/2 inch stock to see if it would work. I planned to locate on od of stock to support the material. I wanted to use brass bolts to run on od as support but couldn't
    find where I had put them so I just used plain bolts for trial. I drilled one hole
    .25 dia to hold a round carbide cutter that I ground end down half way to get it on center. Then turned tool 90 degrees round in vice and moved this next hole a bit closer to front of tool so it would be in front of cutter. Then turned tool another 90 degrees and drilled it as second support. Then I tapped these last 2 holes 1/4 20. Then I drilled and tapped a 1/4 20 hole over the cutter bore to hold carbide round cutter in place. Jim
    Cool, awaiting pics
      Originally posted by Tony Ennis
      Cool, awaiting pics
      What he said
      Bill in SE Idaho
      With enough time & motivation anything can be fixed
        Yep...you know what they say.. "It never happened if you don't have pics"
          hey torker!
            Where do the chips go?
              Box Tool
              Looks like it does a good job! How about some pics of the tool?
