The place that did my spray in bed liner sprayed the water tanks of a lot of fire trucks. Not too large a port but larger than a handhole. The material was a 100% polyurea product and was hot applied. I can't remember the brand right now but 10 years of beating it hasn't phased it.
Leaky tank problem
The Rhino mention is a good lead, apparently they make a tank lining spray. Video here: http://www.youtube.com/watch?feature...s0HDIfiQ4sideo
There's a dealer nearby who handles their truckbed product, will see if they can come and do this...and what kind of $$$ they need....
We would use a lining called tnemec we sprayed on the inside of the frac trucks we built. It is a concrete lining used to line the acid tanks. It is a term much used in general as Zerox is used for copies. As in "Will you Zerox this for me?"
If you use Tnemec it will outlast the rest of the train!
Tnemec is cement spelled backwards!Location: The Black Forest in Germany
<big sigh> Turns out these are not just coolant tanks, they are the intercooler for the oil system and are full of pipes, radiator fittings and other stuff to within centimenters of the sides of the tank....and even if not, according to the local Rhino dealer, too small to get their wands into for coverage, even if they were empty. Nothin' is ever easy. Thanks to all who have replied, your input is much appreciated!
