Follow-up on Screw Cutter
  • Follow-up on Screw Cutter
    Milled a 1/2"x1/2" slot in 6061 bar stock, bolted on an O-1 backing plate (drilled and tapped and hardened) , and used a 1/2" lathe tool blank. Works like a charm! No burrs, was quick to make, one of my successes. Thank you all for your input. The ability to tap into the collective intelligence and experience is truly amazing. Again, thank you
    Horst,
    Great, got any pictures to better illustrate what you did?
    Thanks
