pin size for 5/8" knurls?
  • pin size for 5/8" knurls?
    i just picked up a box of 12 knurls for $3.00 at a second hand tool shop. since i never got much tooling when i got my lathe, i decided for that price i'd try making a knurling tool. i got 6 pair total - 3 different pitch pairs in straight and left/right angled. they measure 5/8" diameter by 5/16" wide (within a couple thousandths per my 20 year old chinese calipers).
    the center hole is what i have a question with. all i had for fitting was a drill index, and 7/32" is the largest size bit that fits through. it did have a slight amount of wobble, but i'm not sure how much slop is normal for this application. 6mm is virtually identical to 15/64", so it can't be a metric hole. i'm thinking i'll try finding some 7/32" hardened pins and give it a try, unless someone knows what the exact size rod should be? i assume a 5/8"x5/16" knurl is a common enough of an item that someone must have the same size ones to know what the center pin should be?
    Do you have transfer punches? One of them may give you a better idea of the diameter. Or use your calipers?
      For my Aloris 5/8" x 3/8" knurls the bolt is 1/4" and it's hardened. There isn't much play when you slip the bolt through the knurl. The shank is also ground so it's a smooth surface for the knurl to turn on. I don't think a regular bolt shank would be toleranced properly or round enough.
      JL...............
