I am in need of 2 RFQ's....
  • I am in need of 2 RFQ's....
    I cant find the RFQ section in PM...
    I am in need of 2 RFQ's. Both are for fasteners.
    RFQ 1 is for double end studs but need a CNC mill or maybe CNC lathe. Nuts are involved. Material is ASTM A193 B7... sizes are 1.75 and 2" diam by 34" long
    RFQ 2 is for fasteners also. This is for a production quote. 5 different pieces ranging in quantities of 1200 to 5000 per month. Ability to hot head forge would be a huge plus but not required. Parts are all CNC parts. Mill and lathe. Material is a European steel (42CrMo4) very similar to 4140, that will be heat treated to a spec similar to ASTM A197 B7 prior to machining.
    Go to the upper ring hand corner , there is a blue button with
    " PM Classified " written on it, your arrow must touch the white writing to be sent to the classified area, scroll down and you will see the RFQ section on the lower right.
    Link: http://classified.practicalmachinist.com/
      Hmm, I see it now.. only 1 posting for a RFQ? Did Don kill it somehow?
        Does it matter where in the country this is done? The size and quantity pretty well sends it to a commercial shop. PM me if your are interested in a Seattle area shop.
        Pete
