Technically I think the student is a bench lathe, right? Its on a steel
stand, and I don't know if the stand is tough enough to level like
floor (engine?) lathe.
This little student is pretty darn stout. I'm sure it gets poked
fun at in school.
So the tailstock end has two large bolts coming in from the bottom
(through the coolant tray, accessed via the drawer). There are
two (non threaded) holes on the tailstock end, operator side. None
on the flip side. None visible at the headstock end of the casting either.
These wouldn't be the easiest holes in the world to thread.
(I'm thinking jack screws)
From my understanding, as it is, I'd have to shim one side or the
other, between the lathe casting and the stand.. but boy would
that be some tough iterations. (loosen, lift, shim, drop, tighten,
measure, repeat).
There's got to be a better way?
If I hear just winding up the rubber isolation feet on the stand
would do the trick I'd be a happy camper.
Thoughts?
Tony
fun at in school.
measure, repeat).
Thoughts?
Tony
