Springback Question
  • Springback Question
    Evening all,
    In ballizing a tube to open up its diameter I am experiencing 2 thou approx spring back.
    Im using a 4.5 mm ball for the initial trials.
    I need to end up at 4.5 mm +-0.004mm ( about 0.0001")
    I've ended up at 4.445mm.
    Im assuming that if I oversized by 0.055mm, I.e. a 4.555mm Ill end up on the money.
    Anyone got any experience of this?
    Just south of Sudspumpwater UK
    Originally posted by small.planes
    Evening all,
    How much are you expanding the tube? Maybe try boring it a bit bigger first?
    Also if you're using a bigger ball, I should think you'll need to be starting with a bigger bore, so that the amount to be expanded is the same in both cases, to get a predictable result.
    I say this with absolutely zero experience of your process, just trying to think as logically as I can after a rather boozy 'works' Christmas dinner
    Tim
