or, the saga of getting the most out of my used lathe.
caveat: I haven't actually gotten the level yet. the mail stinks. but I've
opened a can of worms and am bending my brain into a pretzel hoping to
figure this out.
granted I haven't had this lathe long, but I was much happier before I
started trying to take measurements.
initial test cuts were showing that I was turning a 0.004"/4" taper!
my headstock must be out of line, right? well during the rebuild I noticed
the headstock was shimmed (in 3 locations).. as was the t/s (to raise it).
shims were about 0.010"-0.015".
This scared me. Didn't notice them during the initial survey. Hopefully
it was some misguided soul. If not.. well..
To get the shims out I took the head off. Didn't know how many or where
they were. Plus I wanted a closer look at the head alignment gizmo on the
cholchester student.
Also I figured that, under the head, i must have pristine ways that I could
use to reference the eventual levelling.. er.. untwisting.
Here's the headless lathe:
here are where the shims were (white arrows). Also notice the red arrow
points to the pin that the colchester's head can be spun around:
using this opposing pin / pointed setscrew gizmo. note that right now its
been taken apart, cleaned, and set between the ways for foto shoot.
normally it is pinned/bolted to the bottom of the head:
figure this out.
