Clutch I built today
  • Clutch I built today
    I built this clutch to go on the Festo rotary actuator. It is set now to rotate 180 degree's. I will have change the setting to 90 degree's. It works really good and the clutch was a lot of fun to build. The second pictue if you click on it a video will play. Very bad quality but you will see the jist of what I want.
