I am looking for opinions about enclosed rotary screw compressors (RSC)
in comparison to equivalently rated enclosed reciprocating piston
compressors (RPC).
For example:
Before beginning my search, I thought that rotary screw compressors
made less noise and required less room than reciprocating compressors.
Yet, as shown above, the RSC version is not much quieter than the RPC.
The RSC's smaller dimensions are due in large part to its smaller capacity
tank (60 gal vs 80 gal).
Another consideration is that the RSC appears to be more complex. The
rotary has an oil separator and some other components which the
reciprocating does not have. How will an RSC compare with an RPC as
far as routine maintenance cost & frequency, average service life and
rebuild costs?
Which design would stand up better under an intermittant operating
cycle where the compressor might stand idle for 2-3 weeks between
usage? Would either or both require preparation before use after
standing for extended periods?
compressors (RPC).
For example:
- Quincy QGS5-1-60
- 5HP/1Ph
- 16.5 CFM @ 150 PSI
- 60 Gal
- 62 dB
- LxWxH - 56" x 22" x 50"
. - Quincy 251CS80HCBX
- 5HP/1Ph
- 17.2 CFM @ 175 PSI
- 80 Gal
- 64 dB
- LxWxH - 70" x 28" x 58"
rebuild costs?
