Anyone know how to break the chip when lathe cutting plastics that produce long, stringy chips? The "bird's nesting" is a PITA.
Chip breakers for plastic
vacuum cleaner right behind the cutting tool, suck the swaff up as its made.Play Brutal Nature, Black Moons free to play highly realistic voxel sandbox game.
Originally posted by alsinajAnyone know how to break the chip when lathe cutting plastics that produce long, stringy chips? The "bird's nesting" is a PITA.
I seem to have solved the string problem when I switched to a CCGX AL H10 insert designed for cutting Aluminum. It didn't break the string but it no longer piled up ahead of the cutter in a big mess. It shot the string off to the right where it landed in a big pile. One time it was shooting over my right shoulder and landing in a pile on the floor beside me so I put the garbage can there. It just shot right into the can.
Ernie (VE7ERN)
Originally posted by beanbagYou don't. Best you can do is set the right DOC, feed, and chipbreaker to aim the string somewhere convenient.Forty plus years and I still have ten toes, ten fingers and both eyes. I must be doing something right.
Originally posted by bob_sIf you can cool the plastic to below its ductile to brittle transition temperature it should form chips rather than stringy crap.
Nylon by comparison is much easier, as you only have to get that below 50degC.
