19/32-32 Tap. Help
  • 19/32-32 Tap. Help
    need help finding a 19/32-32 tap, Victor, MSC etc aint got em..
    Appriciate any and all help
    mike
    Mike Hunter
    www.mikehunterrestorations.com
    Try Travers Tool. It will be a special and will need to be custom made, so you're talking about an expensive tap.
      Are you sure its not a M15 x .8 It comes out really close? What is the application. There are a lot of specials out there that are not standard
        It's a thread size that Winchester used circa 1873-1875, pretty sure it's not metric
        Right now single point cutting it...rather tap it
        V/R
        mike
        Mike Hunter
          Try a sewing machine supply house, they were known to use some very unusual thread sizes. First one comes to mind is M J Foley, but they might have gone out of business. They also used a lot of flat head and cheesehead type of screws similar to the weapons industry. May have been some connection between the two industries. Bob.
            I had some special 8-36 taps and dies made by Western Tap, and the price was quite reasonable. They were very accommodating and approachable, so everything was handled with my initial phone call. One-offs cost the most, but their specialty is small quantities - up to a dozen, I think.
            http://www.westerntap.com/
            Frank Ford
            HomeShopTech
              I can find 9/16-32 which is 1/32 under...
              I can find 5/8-32 which is 1/32 over...
              That was from Travers Tool...
              I also checked Wholesale Tool and KBC - no luck.
              Andrew
                Hit a Winchester forum.
                  if its that much trouble finding it, make it
                    V/R
                    mike
                    Why not just make a tap since you're already set up to make the thread?
                      Field tool and Supply in Chicago.
                        Frank Ford
                        Called Western Tap, they had one in stock, thanks
                        Mike Hunter
