For those lathes (older lathes) that come without splash guards or a full enclosure, what do you/would you use behind the machine to contain the oil & coolant sling?
I'm currently re-sheetrocking the shop and want to put a handle on the mess. I figured maybe plastic laminate or Masonite might be a good surface, although plastic laminate can be pricey. Suggestions? Non-porous to wipe clean ? or will that allow oil to drip down to the floor?
Thanx,
Thanx,
