Shaft and Pulley Repair?
  • Shaft and Pulley Repair?
    I've got a messed up shaft on a 1hp AC motor with a 5/8" shaft. The pulley is also worn and wobbles. It looks like a key was missing and the set screw was just cranked down as a hack repair. It is off a air compressor.
    My first thoughts are to bore out the pulley TIG weld in a new center, machine new hole and file cut keyway. It looks like it was a 1/4" keyway. I've got to file it because I don't have a broach for cutting keys.
    On the shaft I was going to machine it down sleeve it and recut key with an 1/4" end mill.
    Based on my scrap pile I've got some 5/8" 4130 for the motor shaft and 1" 1020 for the pulley.
    I've never done a repair like this before. Is there a better or more efficient way to do this? Any pitfalls i might be in for?
    https://picasaweb.google.com/lh/phot...eat=directlink
    Why not just buy a new pulley? They are cheap. Unless it was something special.
    You can braze to the cast but you really are not going to tig to it. And I have never had real good luck with sleeves on pulleys.
    Take a file and clean up the shaft. Make sure you use a key and it will be fine as is.
      I agree surplus center has a v-belt pulley about that size for ~$5, but isn't a standard v-belt. It a odd 6 groove belt. Kinda like a an automotive serpentine belt, but not. It has 390J6 on it and oddly enough it says it it "made in the usa".
      I agree brazing would be better on cast iron. It doesn't appear to be cast iron. It looks like it is mild steel. That why I feel that welding it will be ok.
      It looks like mcmaster has the belts. It is called a "J-section v-belt"
        Is there a motor shop near by you that could put a new shaft in it for you???
        JL.................
          Unless there is enough wear in the pulley to make it wobble excessively, a good cleanup with a new key, new setscrew and some JB weld or similar filled epoxy will likely make a permanent repair. Devcon and Loctite used to make adhesives just for that purpose and still do as far as I know. Heat will soften the epoxy if you need to take it apart later. If there is a lot of looseness adding a suitable shim to help keep the pulley straight while the epoxy sets might be in order.
          Don Young
            If you machine the shaft down and sleeve it your going to separate your sleeve or most of it when you cut the key way.
            Since it's on a compressor....... I would make sure it's a good tight fit with no lash in it because the quick starts of the motor will eventually take it's toll on it again.
            JL................
              Then it is a poly-v belt.
              It could be steel then.
                Buy or make a new Poly-vee pulley - dead easy to make.
