Where to find a B&S #9 Arbor?
  • Where to find a B&S #9 Arbor?
    For a Vernon Horizontal Mill....
    Hi...
    I lucked upon (I think) a nice Vernon horizontal mill a couple months ago.
    It has a short arbor, but nothing to match the over-arm support length. I would like to find a longer 1" arbor (maybe a 7/8 and 1&1/4 too), that is a #9 B&S taper. No sure how except maybe to try to watch Ebay for who knows how long?
    Can anyone point me to a source of a reasonably priced arbor for this application? I paid $375 for the mill in very good shape, so I don't really want to pay an arm and a leg for an arbor, if you know what I mean. I did buy a set of end mill holders from Tools4cheap that look good.
    I still need to get a VFD for the mill too...costs do add up...approaching retirement...so many reasons not to spend too much for a retirement hobby!
    Thanks in advance for any advice and/or pointers!
    Bill
    You may want to get a 1" endmill holder and add a 1" piece of TGP ( turned, ground & polished) to it and make your own arbor.
    go to
    www.travers.com/
    then enter
    Brown and Sharpe
    The endmill holders will come up.
    Finding #9 is not the easiest in todays modern market. Keep trying
    The Mill you have was a Diamond Mill during the war, and they sold it to Vernon. Then it became a Sheldon Mill , when Vernon sold out in 1959 (?)
    I had a Diamond years ago.
    I have the Sheldon parts list if you want a copy...just PM me
    Rich
    Green Bay, WI
      Such a thing can be made, but it would certainly be easier to buy one. Here in New England, two well-known used machinery dealers are www.plazamachinery.com in Bethel, VT, which is a long way from anywhere unless you live in central VT, and www.brothersmachinery.com/ in North Andover, MA right off route 495. Shipping on an arbor would not be exorbitant, however, so location is fairly irrelevant.
      [edit:] As usual, Rich has a good idea about how to make one.
        Not that it really matters, but from what I have seen, there has been a bit more B&S tooling on EBay this past week or two...not sure if such is cyclical or not...5C collets w B&S interior tapers, MT with B&S taper cutters on the other end...that sort of thing...hope some if its still there if I end up with a given mill later in spring
          Thanks for the info....I really appreciate it! Great help!
          Rich,
          I was wondering where I could get an endmill holder... I did buy a set from Tools4cheap but the largest was 7/8"... the travers.com site has a 1" which will be perfect for my needs if I make the arbor myself. Thanks for that link!!!
          I did download two parts lists for the Sheldon machines and have them printed out. Thanks for the offer!
          SGW
          Thanks for those links. I will be in touch with those guys to see what they might have available.
          RussZHC.... I have been keeping an eye on eBay and will continue to do so. I am not seeing much available that is #9 B&S taper, but hopefully I will get something one way or another...either by making something myself as Rich suggested, or by finding something ready to use...
          Again, thanks for the info!
          Bill
            I second the motion of using an endmill holder to hold a piece of ground shaft. The shaft can also be found with a keyway already cut. Just cut/grind a weldon flat in the end to be held in the endmill holder and modify the other end for your over-arm.
            This is basically what I plan on doing for my mill (45 taper).
            Andrew
              go to
              www.travers.com/
              then enter
              Brown and Sharpe
              Rich
              Know this is an old post but I just purchased a Vernon model no. 0 mill. It has no arbor. Do you know the length of the arbor? I'll probably make one of my own. Reason I ask is it also is missing the overarm support and overarm bracket; so I'll be making those also.
                Jbar
                The arbor is 9 or 9-1/2" but 1-1/2 or 2" of that is used for the Support Bushing/Bearing that runs in the Arbor Support.
                The effective arbor length for cutters is 7 1/2" Plus the Bushing ( 1-1/2" or 2" )and then the Locking thread/nut
                They used 3/4, 7/8, and 1" Arbors on that machine.
                terrific mill !
                Rich
                Not sure of the model number "0" as i didn't have a name plate, but pretty sure it is the same.
                Oh, by the way, B & S # 9 tooling is available at Victor Machinery
                https://www.victornet.com/subdepartm...oling/410.html
                Green Bay, WI
                  Jbar
                  Second comment, since you may have to build your own Arbor, consider this.
                  You could find a inexpensive arbor for another machine, like this
                  https://www.wttool.com/index/page/pr...+Machine+Arbor
                  and either hard turn the taper to a #9 , or slice it off and put it in a collet , which would shorten the arbor to a more manageable size.
                  If you use a collet, I would cross drill the two pieces together with a carbide endmill and then pin it permanently. You would also want to cross-drill a collar next to the collet as a shoulder so tightening the cutters does not counteract the drawbar force.
                  buying a commercial arbor gives you all the spacers/collars and you don't have to worry about getting a banana shaft from cutting a keyway.
                  Rich
                  Green Bay, WI
                    Making an arbor is really not that hard to do. Easier if the arbor and the lathe taper match, but not that hard.
                    You will certainly want 7/8" and 1", and I would add a 1 1/4", because you may find cutters for that size, and they may not be large ones. The 7/8" will come in handy for gear cutters.
                    So far I have not needed a 3/4" for my mill, (which is not a Vernon). the brand of mill does not determine what arbor size you need, the cutters do. I bought several buckets of cutters from a shop years ago for 50 bucks after I got a Lewis mill, and the three sizes of 7/8, 1", and 1 1/4" are all I have needed.
                    I made the 7/8" and 1 1/4", the 1" came with the mill.
                      Found mine on Ebay for $60 shipped.Click image for larger version
