Swapping new chinese power feed for old bridgport, hints?
  • Swapping new chinese power feed for old bridgport, hints?
    The original table power feed on my 2 hp bridgeport was DOA. Everything I read about it suggests it would be an expensive and/or time consuming fix. It looks like this:
    http://www.ebay.com/itm/REFURBISHED-...#ht_753wt_1110
    I purchased a cheapo import servo power feed. It claims it fits all bridgeports and many others. It's similar to this:
    http://www.ebay.com/itm/135-LBS-X-TR...ht_5615wt_1242
    Upon receiving the device, I think I don't have enough parts. The instructions are pretty unclear/obtuse. It physically fits where the old one comes off, but has no "intermediate shaft" to get from the bevel drive gear to the end of the table drive screw. I need a shaft extension of some sort to make this work.
    Can I purchase this separately? Is there a kit? Recommendations?
    Thanks in advance,
    troy
    You either need to swap the lead screw to the non-feed type, or, make/buy the extension for the old screw. Go to Servo's web site there is a drawing of the shaft extension, part number 2368.
    Here's the "normal" shaft dimentions : http://www.servoproductsco.com/specs...00_206_225.pdf
    This might help somewhat : http://www.servoproductsco.com/specs/0206_OLD_80092.pdf
    The shaft extention is show on the last page of this doc : http://www.servoproductsco.com/specs/0206_NEW_80092.pdf
    What is wrong with the BP unit? Is it a 6F or 8F?
    Unless you have something like a bad motor armature (I had one), it's not all that expensive to fix. And they are very good..
      I did the powerfeed install on my Burke Millrite years ago, maybe this will help:
      http://www.tdkmotorsports.com/shoppics/burkefeed.html
        Recommendations?
        Thanks in advance,
        troy
        Well both of those are very repairable, I've done so on the ones here
        in school.
        ...lew...
          Excellent information and thanks!
          As far as repairing the current unit, I don't want to do component level repairs on a 30 year old board. The motor itself looks pretty bashed up. I don't quite have the skills to substitute a generic pwm board as a hack/update/fix. Plus, I have the new chi-com unit, so I'm going to press on in that direction. I debated for a while though...
          Even in non-functional condition, the old one is worth some money, so selling it will pay for part of my new parts.
          Thanks again for the info.
          Michigan Doug.
            ha, the 30 year old stuff is easy! Most just put in a stock replacement card or send the old one to a number of places that fix them for a fixed fee.
