Need help in Identifying part
  • Need help in Identifying part
    I need help in identifying this part. It's the part in the middle of this picture.
    It is threaded inside and threads into a threaded rod. I don't know the thread size, it's small and the overall lenght of this is maybe 3/8's. It's stainless steel I believe. anyone know what this is called and WHERE I could purchase a quanity of them? Thanks in advance!
    Randal Berry
    Uploaded with ImageShack.us
    Do a search for swageless mechanical fittings. What is the end use for them?
      Looks like parts from a small turnbuckle or tie rod arrangement
      similar to the bottom of this page:
      http://www.pacificmarine.net/stainlessturnbuckles.htm
      or parts here:
      http://www.pacificmarine.net/quickattach.htm
      http://www.pacificmarine.net/quickattacheye.htm
      Phil
        It looks like the adjusting part at the end of a bicycle brake cable.
        Ernie
          If you have a print, Misumi will make them for you in China.
          Any quantity you want.
          --Doozer
          DZER
            Thanks everyone for the replys! They have been very helpful!~ The part is threaded on an internal rod inside a pair of tongs.
