Threading question
  • Threading question
    I have been watching some threading videos on U Tube. On a 1” diameter 16 tpi steel bar similar to a rifle barrel shank They were taking heavy enough cuts to produce a continuous curling chip. Starting a thread I may take a couple of .015 cuts then reduce to .005 and on down. What DOC do you take and why?
    Byron Boucher
    Burnet, TX
    SECO has a chart floating around that give a recommended depth for each threading pass. But I do what you do and at around 16 TPI I stop short and take .001 passes tell I get it to size. With a deep thread there is more drag on the cutter and more chance of flex.
      I use HSS only on the smaller pitches and spend more time honing the tool so it produces a continous chip at very light cuts usually .002 or less.
      I also start rough with .006-8" passes until the last .005",then drop to .001 and finish up setting the topslide in .0005" for the last couple passes so both flanks get wiped clean.
        When you pay 300+ bucks for a top quality barrel, I tend to treat it carefully. It's not a production shop, or shouldn't be. Starting out with a .015" on the compound, then a few .010s, and back down to the final couple passes at .002 or .001. For a 16 TPI, somewhere around .050 to .052 advance on the compound should do it, depending on the receiver threads.
