Anyone know about Ab Arboga Maskiner machines?
  • Anyone know about Ab Arboga Maskiner machines?
    http://tallahassee.craigslist.org/tls/2842551730.html
    Looks like it has x and y axis movement, but it's hard to tell from the photo. Any good? Worth having, considering a VFD would be needed to make it run?
    Buy it, quick. Incredible price, very good machine.
      Get there fast- RUN !!
        Buy it now if you want it as a drill press. As a mill I can't say. I have a Strands and it is very similar and a very good medium duty drill press.
          I have used a similar machine for milling and they are useful for that, although they are excellent as drill presses. They are better for milling compared to most lighter chinese mill/drills that I have seen(and the one I own). For that price I would not hesitate, assuming it runs. The motor can't be replaced(at least not easily, a rewind is probably more practical).
          Some info on Arboga here: http://www.lathes.co.uk/arboga/index.html
          One thing to consider if you want to use it for milling is that it doesn't have a drawbar. Instead it has a threaded spindle nose and some "plates" for holding the toll in place, make sure you get these if you buy it.
          Around here Arboga(and Strands and Solberga) are the standard drill press found in almost every shop.
            one off integrated motor ...and phenolic gears .
            motor often fails
            gears often strip
            i draw that conclusion from over the years ..
            almost anyone that has one of these ..and has posted on the net is talking about where to get the gears made or how to get the motor sorted.
            all the best.markj
              Yeah, yeah, yeah, yeah, but, BUT.....
                Nice drill. Dont mill with it.
                  Why not ?
                  It is a milling machine.
                  I had one for years, built like a brick $hithouse, round column but the rack is secured to it so it hold position if moved up or down, small quill movement 3" if I remember.
                  Three phase two speed integral motor, ours were 440 volts as as such would not run off a VFD, If the US model is 220v then it will.
                  Very nice well made machines and if the range of movements fall within what you want to do with it then it's cheap at that price but has probably already gone.
                  Mark mentions the inbuilt motor giving problems but to be honest I haven't heard this or the gear problems. If the motor goes give problems the stator is easily removable for a rewind.
                  End of spindle is threaded 62 x 1.5 or similar instead of a drawbar.
                  I made a top hatted threaded bush up and turned a groove into standard MT3 holders and fitted a circlip. When the nut was tighten it forced the circlip up and so held it in the taper.
                    I do not know anything in particular about this model, but in general Arboga machine tools are excellent. I do not see how you could get hurt at that price.
                      Why not ?
                      Agree with everything you say John.I have one too and seen hundreds more.
                      I have repaired one motor and no gears for all of my customers over thirty odd years.
                      Quill travel on mine is more than 3" I think.
                      Sorry Welsh Mark,you need to treat them more like your women and don`t pull the wool out.
                      Mark.
                        its just stuck in my mind
                        Arbouga equals
                        motor trouble and gear trouble ...
                        i think the posts are on the PM forum ..
                        think there is about one mention of a machine that isnt in trouble ..and three mentions of machines in trouble...with threads lasting for weeks .
                        all the best.markj
                          I seem to remember big long threads from a poster in Oz who had posts on every forum on the net asking about how the motor was wound.
                          Despite getting answers early on he kept posting and asking and just going round in circles.
                          There was one about someone who had dropped his and broke it.
                          That head on these Arbogas has been used in loads of different models,copied in other makes and built in tens of thousands for over forty years,for a No3 morse machine it is surprisingly strong.
                            Why not ?
                            Just bc it has an XY table does not make it a mill John. Without further research I cannot speak for this particular one, but do know that Arboga made models that were drill only, and I was under the impression that was the majority of their business. I have also read that some of these had upgraded bearings for milling, but when in doubt I play it safe. Ive seen far too many nice machine tools ruined by misuse, and also seen far too many drills and jig bores mistaken for mills.
                              Yes, most are for drilling. This one looks to be the drill/mill model though, if it has the threaded spindle nose it is made for milling.
