private message
  • private message
    My private messages is listing 65,533 unread. I might not get to answer all of you tonight but be patient I will get to all of you.
    Odd, did this just come about? My unread icon on e-mail at work popped off yesterday afternoon showing 2800 some unread e-mails.
    I'm obviously nowhere nearly as popular as you.
    I bury my work
      It’s a common problem likely caused by the outdated software that runs this board. There is nothing I can do about it on this end and a check of your file would show the correct number to me.
      To fix it, save all messages as a text file, or however you want to do it, and then delete all messages from both the in and out boxes. That should fix it, at least until it happens again.
      George
      George
      Traverse City, MI
        I thought that the total of in and out PM messages on this BBS was limited to 50.
        I just checked the PM messages and its working fine so I have no problems with the VP BBS software in that regard or at all.
        Perhaps the BBS is not at fault at all.
          In computerese it's minus 3, which sheds another light on your popularity.
            That's about right for me as I have no measurable personality at all.
            Negativity is a way of life.
            And I try hard to make sure that it stays that way!!
              Black Forest it all your friends,be happy!
              I had it last week & it cleared up on it's own.
              country, in easy stages."
              ~ James Madison
                You probably have a PM which contains no actual message. Delete it and things should return to normal. The empty message may turn up a few times before all is good.
                Phil
                  I did post a PM message to BlackForest through this forum last week. I didn't receive a response but was unsure if BlackForest had elected to not respond.
                  If you would like for me to resend my message, let me know, otherwise I will respect your decision not to respond.
                  Fred
                    Oh, that means you have one message you haven't read. Mine shows 65532 unread, and there are none that I haven't read.
                      2^16? Sounds a bit too convenient!!
                        What happened to the other three?
                          Perhaps they were BF's "admirers" and the messages may be their "Valantine's Day" "greetings" - or what-ever.
                          I am quite envious as I never get any Valentine's Day messages - can't see why. Is there something I should know??
                            I did have a message with nothing written in the body. I deleted it and all is well now. I am a little depressed. I thought everyone loved me.
                              Well of course we do thats why we all sent you a mystery Valentine.
