Are you thinking about one of these?
OT-Making a Sapling Puller
I had a skid loader bucket with a smooth edge, and wanting
to dig more I trimmed it with a torch, to a "semi sawtooth" pattern.
As an afterthought, I found it works great on brush/small sappling's.
Lay the bucket flat, drive in, as you feel resistance, lift, continuing
to push forward (keeping them jammed in the "v"'s).
To unload, back up with the bucket on the ground to unsick.
Works very well to not disturb the soil too much (ripping the
trees out, leaving the nearby grass intact for erosion control)
We have over 2000 acres and a problem with cedar trees. I made a V shaped fork from an old grader blade, backed up with mild steel, sharpened the inside edge and mount it on the loader of my 4020. Put it about 6 inches under the ground and then just push and lift at the same time, it will take out a 6-7 inch (diameter) tree with very little effort. Then just pick up with the loader and put them in a blowout.
RossGUNS Don't kill people
Drivers using cell phones do.
I agree with the chemical treatment option. 75/25 mix of diesel and tree killer (there's several options) applied to the stump and you'll have dead roots rotting in no time.
Cut them, treat the stumps, then come back and brush hog them down level.
Some trees (American plum, poplar, etc) sucker profusely. Ripping the trunks off will give you 50 new stems. You have to kill it first.
Originally posted by Jim ShaperI agree with the chemical treatment option. 75/25 mix of diesel and tree killer (there's several options) applied to the stump and you'll have dead roots rotting in no time.
I have a brother that used to work for a Christmas tree farm in Montana. They pull the stumps after the trees are cut for market. He mentioned a hydrolic clamp the fit on a Bobcat. Google images shows such a critter in the images of Christmas tree stump pullers._____________________________________________
Oregon Coast
If the ground allows your Bobcat to get a bit of bite and the scrub is decently large diameter, I would simply weld up a small rock bucket out of scrap. Barring that, I would either use a choker and yank them out. If the scrub isnt too large in diameter, a bush hog will make short work of it. Considering youre only doing an acre, it seems almost like a waste of effort to fab anything you might not use otherwise."I am, and ever will be, a white-socks, pocket-protector, nerdy engineer -- born under the second law of thermodynamics, steeped in the steam tables, in love with free-body diagrams, transformed by Laplace, and propelled by compressible flow."
Originally posted by rwsAbout an acre or so. I would start working and keep going as time allowed. I agree that pulling straight up would be best, but then again I would have the ability to wiggle it back and forth if it were stubborn.
The idea of a choker, or post puller is the right thing, but getting down and back on for each sapling would wear me out!
I have cleared a fair amount of this stuff just grubbing them out, but chasing those small damn things and all the digging needed to get that one small sapling is a pain.
I once heard a now 17,000 acre forest in WA state was started from 1 poplar tree, anything with a sucker root system can be hard to control. I brushed 50' x 1000' strip clearing my powerline right of way before building and knocked down probably 500 old growth mature poplars, witness 5000 saplings to replace. You can either choose chemical or mechanical. They used to have a rotavator which was basically a heavy rototiller with a detroit diesel powering it pulled by a large dozer for cleaning up the last of the root system before being turned to agricultural land.....don't see them much anymore as most bush is gone.......
Texas and Oz seem to have to deal with a lot of subsurface root systems and a root plow is the cheapest and most effective......here are some pics of different setups geared for multi sized machines......
Opportunity knocks once, temptation leans on the doorbell.....
Originally posted by hardtailI once heard a now 17,000 acre forest in WA state was started from 1 poplar tree, anything with a sucker root system can be hard to control. I brushed 50' x 1000' strip clearing my powerline right of way before building and knocked down probably 500 old growth mature poplars, witness 5000 saplings to replace. You can either choose chemical or mechanical. They used to have a rotavator which was basically a heavy rototiller with a detroit diesel powering it pulled by a large dozer for cleaning up the last of the root system before being turned to agricultural land.....don't see them much anymore as most bush is gone.......
http://www.google.ca/images?q=root+p...ult_group&sa=X
FWIW, I think a distant relative still has an 8' rototiller they use to break bush land out by Caroline. A pretty aggressive machine - the only machine they had big enough to control it was their TreeFarmer skidder.
For small saplings, the least expensive option that is still affective in a choker style is to weld a grab hook on the outside of a stub of pipe. Stick the chain sans hook through the pipe, around the sapling and hook onto the welded hook, hook opposite end of chain to towing unit and pull. Repeat. Not quick, but works for sticks over 1" dia.
The other option is some kind of grubbing blade.Last edited by camdigger; 02-22-2012, 11:19 AM.Design to 0.0001", measure to 1/32", cut with an axe, grind to fit
Think it through carefully. Many fancy things can be built. I have grubbed small and big trees with a 46 hp JD and a loader. Tipping the sapling a bit breaks a few roots and loosens the soil, use the leverage and a trees inherent strength at the stump to your advantage. Then try to get under it a bit and lift. If you want the stump out then a dull 'L' shaped hook attachment might be better than a shear. Bigger trees up to 15" dia I use cable and 'luff' rigging, choker it 8-10 feet up. Pulls them right over and gets the stump too, at least in our soft soil.
If you have hard stone filled soil I think chemicals.
