Clip art
  • Clip art
    Hi, Does anyone know where to get some free clipart of gears? Or some nice renderings of verious size/tooth count gears I could use for a business card border?
    At this point im considering opening the remains of that photocopyer I saved for the numerious gears I suspect are inside and photograph em..
    Give me some rough art ideas and I will make it for you.
      I started life as a graphic artist. Id be happy to draw some up for you
        here's some I drew I while back
          Do you need these gears to be generated?
            I cut vinyl signs and stickers as a side business, so I have lots of clip art. I do believe I have a variety of gears on my home pc. I can look later today if no one else comes through.
              Wow two offers, Thanks. Not sure how to decide, Evan did reply first however...
              I was thinking something like a boarder of 2d meshing gears, where the corner gears are about 2 times larger then the rest. Not sure if the boarder gears are to be zig zaged or alternate sizes..
              the overall size would be 4.25" X 5.5" as it will be a small 'poster', I guess I should be thinking about regular business cards too, So I will likey need a 2"x3.5" version as well. I was thinking about 300dpi since thats the standard printing res these days?
              Gears themselfs I was thinking of a simple spoked design like http://howto.nicubunu.ro/gears/gears_16.png
              Or do you think that design might be too busy?
                Generated? Well, I need a couple gears with the same pitch but diffrent tooth count, And idealy an odd number of teeth so that they mesh side by side without having to rotate each gear (I think that works out?)
                    Oh, And maybe more then 4 spokes on the larger gear?
                      Originally posted by Evan
                      Hahaha. Nice. But I am not going by Black Moon consulting...
                        That can be changed. Incidentally, I never use clip art. It is always my own work.
                          I also never use clip art. My stuff is all plain!
                            Yea I was kinda looking for something much more... simple... and mechinist related... Like a boarder made of meshing gears. And then I could fill in my own text and update as needed.
                              Sketch an idea and e-mail it.
