Can anyone shed any light on the advantages/disadvantages of key operated or lever closing collet chucks.
I would like to get a collet system for my Colchester lathe.
It seems that the lever operated system is much more readily available than the key type. Is there a reason for this?
I assume that the lever type is more complex to install and remove as the lever assembly needs clamping to the bed and addition to mounting the chuck on the spindle?
Also does the lever get in the way?
Any other feedback on the Burnerd multisize collet system?
Thanks in advance for your response
Stuart
Stuart
