Got a possible job coming up to do some work with my little CNC lathe that requires machining a feature on the end of 1/2" hex stainless stock. The lathe has an ER32 chuck only.
So far I've been unable to find ER32 hex collets so I guess it comes down to making a hex ID split bushing of some sort. I am broachless; anybody have a brilliantly simple solution or a source for ER hex collets?
Hmmm, just as I was going to press the submit button, the lightbulb flashed on and I thought about using a thinwall 1/2" deep socket with the square drive end cut off and slit horizontally. That ought'a work; should it be split at a point of the hex or the middle of a flat?
