If you have access to a mill or a lathe function where you are able to use either the graduations on the machine or an indicator on a tool why would you manually do a layout...it only provides a visual reference and usually when I'm machining enough swarf is produced that you can't see your marks anyhow. Not only that but your accuracy is greatly improved (I would think).
Am I overlooking something?
I can see it if you're doing relatively loose tolerance work on a drill press but for tight tolerances it doesn't make sense to me (forgive me for I am a relative newbie
