Hello all,
I would appreciate help on what these may be worth before I post these to fleabay if it's worth it, here's what I've got (all used):
- One Lyndex boring bar? (apparently I'll need help with this) left-hand 1.5''x1''x8''; KTFR 865C insert TP54; Insert not good anymore, seat OK
- One Kennametal 1.25''x1''x6'' right-hand turning tool; NELL 204D insert NP44; no insert; seat chipped but OK
- One Kennametal 1''x1''x6'' left-hand turning tool; DVJNR-163D insert VN-33;
insert good; seat OK
- One Carboloy turning tool 1''x1''x6''; TBL-16-3P; insert not good, seat OK
Four brazed carbide turning tools (.5''x.5''; two .75''x.75'' and one 1''x1'')
I won't be using these simply because I'm quite comfortable with grinding HSS bits (and am very much enjoying the learning curve) and my SB 16'' and Lathemaster 9x30 are simply not production machines. In the end I just want a fair estimate of what this is worth so I can get rid of these quickly without screwing anyone (or myself).
Thank you in advance for your responses.
