Originally posted by T.Hoffman
My attempt at screw jacks and ACME...
You can get pretty much good measurement with a micrometer and a lttle patience, but with trapezoidal thread it doesn't matter if the tip is a little bit narrower/longer, it just makes more extra space at (or outside) the threads major diameter.
What I have done external trapezoidal threads, I made a HSS bit that was narrower than what was needed and just moved the cutter with the top slide to get the thread width correct.Amount of experience is in direct proportion to the value of broken equipment.
Originally posted by RussZHCAny chance of a few shots of the internal threading bit?
The very tip of the internal bit may be hard to see because it still had some residuals left on there from the process.
The larger boring bar on the bottom is the one that proved to be too big in my bored hole for doing this job.
Thanks, now this
The right way is with an optical comparator.
Attempting single point threading is on this spring/summers list of things to do and I am still trying to wrap my head around grinding such small/fine surfaces...start large I guess and work my way down
Outstanding.
Had on my list for a while a 2-stage (telescoping) set of these to make... Just like yours but where the thing screws into a bigger one.
I struggle to make work that neat though, and would probably end up giving up if I tried to cut an acme!
What kind of knurling tool did you use to allow you to knurl such size stock? Been looking out for a larger one for a while, mine limits me to about 18mm dia.
Originally posted by loplyI struggle to make work that neat though, and would probably end up giving up if I tried to cut an acme!
My knurling tool is a homemade scissors type, made by an older machinists and given to me after he made an improved version. I think I could do up to 3" diameter, but never checked for sure.Last edited by T.Hoffman; 03-12-2012, 06:13 PM.
