How would you build this? A prosthetic attachment
  • How would you build this? A prosthetic attachment
    My dad is missing an arm but loves to golf. He has always wanted one of these but they run a goo $800. Basically, it is a tube tapered to fit a golf club but slotted to get the club in and out. It attaches to the prosthetic via standard 1/2 threaded rod.
    The hard part is, what to use for the flexible portion? I was thinking of finding a spring of some sort and welding nuts to the end of it for which I could then insert the threaded rod for attachment to the prosthetic. I could then plasticote or cover the spring with vinyl tubing, ??
    http://www.oandp.com/products/trs/sp...ation/golf.asp
    I would think a piece of steel aircraft cable (1/4" - 5/16" diameter) would work quite well.
      At what height is the amputation? What does he currently have to wear that takes attachments?
      How good a golfer is he/was he? If he wants to play for anything more than drinks you may have to consider the energy storage ability of the prosthetic. The guy they call "The blade runner", Oscar Pistorius, aka the fastest man on no legs, has been fighting with the sports establishment over the possible advantage that his carbon fibre lower legs might give him.
      I am currently designing energy storage leg prosthetics for myself to help me out when I have to climb stairs or even just spend a lot of time on my feet. There are a lot of considerations and very small seeming particulars that make the difference between something that works and something that works well.
      To build something that works well for your Dad I would expect it will take several versions until you get to one that does the job the way he wants.
        Might want to give the folks at ParadoxSports.org a holler on this one... They specialize in making the outdoors available to the disabled and there's likely someone on their forum who's already figured out a cheaper solution to this. I've got a couple friends involved with Paradox and they do absolutely fantastic stuff (including adapting my friend Maureen's arm prosthetic for holding an ice climbing axe. )
          I was thinking of something similar to cable, but I had more pieces of it in mind. Get a piece of rod large enough in diameter to bore and thread, plus drill three, four, maybe five holes surrounding the threaded hole, in the same direction, axially. A piece of cable is epoxied into each hole, then they are twisted into a bundle in the same manner as the cable is made. At the right distance, each cable goes into another similar 'boss', and epoxied as well. As long as each cable does at least one complete 'go around' of the bundle, the bundle will be flexible. You might want to end up with a couple of go-rounds. Work some Plasti-Dip into the cables, then basically encapsulate the bundle.
          It's going to be some trial and error to get the right degree of flexibility, regardless of how you make the flexible part. You could use a spring, but in addition to being flexible it will also stretch and shrink. I think you would need to avoid this.
          Another possibility is to use some rubber hose with a steel braid in it. That will be strong and flexible, and will have a well-controlled action as you twist it. I'm thinking you should be able to find a size that would give you the right amount of flex. A bigger problem might be finding the best way to attach it elegantly. A couple of hose clamps is going to look pretty awful. On the plus side, most hose is going to have a curl to it, and you might be able to use this to advantage.
          Of course, if you made it with multiple cables you could put the bend in it to begin with, then apply the Plasti-Dip. It's going to want to keep some of that bend after it cures.
          Some ideas anyway.
            I'd use leaf spring and socket
            One thing apparent from the web page is that the polyurethane connection between the mount and the club socket is a stiff spring to "store energy" from the backswing. I'd start by making the stud mount and club socket in aluminum or stainless with rectangular sockets for the ends of a graphite fiber leaf spring and then epoxy the assembly together.
              So I started on this one tonight.
              1/2x13TPI threaded rod for attachment into the prosthetic. I bought a 1"x5" heavy duty utility spring that I cut to a smaller lenths to prototype with. The spring is pretty stout but allows just enough deflection to give him some "stored energy". My goal is to build a metal slug to fit into the ends of the spring as caps that I can braze to the spring itself. I'll tap and thread those for the 1/2x13TPI. I intend to cover the spring itself in cloth or vinyl tubing to keep him from catching or pinching on something.
              Right now, I see see I'll have some challenge with the depth of the tapered hold as I only have an Atlas 6". I might need to make or buy a longer boring bar. The eccentric piece that attaches to the spring will also have a 1/2x13 TPI.
              Also, my first pass with some map gas, flux and some 1/2" nuts didn't work out so well. I may end up TIG welding them. Not sure how that will pan out if I need to affix something to the springs. I purposefully chose steel and non-zinc coated hardware because I knew I'd be trying to work with it later.
              On a side note, the old man is already good a good golfer. Not great, but he is retired now and is obsessed with his golf habit.
                I think I'd go with a vinyl coated cable between the threaded stud and club handle socket. Then make a mold and cast the whole thing in a polyurethane cover. The cable will make sure it stays attached and has some rigidity, the polyurethane will give some flexibility and energy storage depending on how stiff a mix you find.
                I am familiar with that prosthetic as one of the farmers I do work for has me repair his hook on a regular basis. Well.....I used to. I finally made him a new one and he hasn't broken it yet.
                  Risking a poor joke, what do you think Oscar's "carbon footprint" is?
                  If ignorance is bliss, why aren't there more happy people?
                    Last I heard is that they will allow him to run but he can't change the blades he uses to any other kind. He is currently right near the top in his field against able bodied athletes. Gives a new perspective on the meaning of "disabled".
                      The pictures on the bottom.
                      It looks for all the world like a piece of flexible SS tube used for hazardous area light fixtures. Only the put some shrink tube on theirs.
                      McMaster Carr sells the stuff. I think it's called 'flexible metal hose' or 'flexible metal conduit.'
                        Another approach
                        Just thinking this through, why not a clevis or universal joint arrangement with two end plates and studs on the end plates. Then you could put a spring around the joint and between the end plates. Then you could switch out compression springs to get the stiffness desired and control the joint twist at the same time.
                        I think that it's about time we consider "alternately advantaged" rather than disabled as some of the prosthetics are pretty darned amazing in what they let you do.
                          I reckon you could fabricate this yourself.I am sorry they charge so much for these things as it seems to be the disabled getting ripped off again. You're the man to do it.I would get as much information as you can and with the help of our pals here more knowledgable than I , I am sure you will suceed. Have fun and the very best of luck. Alistair
                            Your cleavis pin idea is interesting. I think I would have to find a spring distributor and get different tensioned springs. I could then pre-cut or somehow adjust preload if it had an impact on the deflection and return of the spring.
                            Thanks for the ideas guys. As with any problem, its always good to gather input on alternative strategies for a solution whenever possible.
                              Alistair, it is called economy of scale. When you are building hundreds of thousands, nickles and dimes of profit are acceptable. When you are building tens of ones, five and dime won't pay the rent.
                              I know this first hand as the tool I designed and am starting to build will maybe sell 200 per year.
                              Pops
