What size clamp kit for my Ab Arborga Maskiner mill?
  • What size clamp kit for my Ab Arborga Maskiner mill?
    The slots measure 0.550" at the top and 0.990" at the bottom. I think that rules out using 9/16" T-nuts with 1/2-13 studs.
    I'm looking at the 1/2" T-nuts and 3/8-16 studs in the 202-4802 set here:
    http://www.shars.com/files/products/...11/page114.pdf
    Is that the best choice? What are those of you with these mills using?
    14mm x25mm?? It's metric is it not!
      1/2" T nuts and then mill the T nuts if needed to fit into the slots.
        Tee Nuts
        My mill/drill is an Enco, I bought the hold-down kit in the upper left of the Shars display. Had touble with the nuts fitting the groove, until I did what Black Moons said--milled the sides down until they fit the table grooves. Its a little hard on HSS mills but I did get the job done.
        No doubt my table grooves are probably 14 X 25 MM .
        Good Luck
        Ray
        P. S. I have never been sorry about buyng that hold down kit.
          Here is another source of T-nuts with possibly a greater selection:
          http://www.reidsupply.com/products/t...s-studs-tnuts/
          Like rock_breaker, I have never regretted spending the bucks for a good set of clamps, studs, T-nuts, and blocks.
            Here is a set of 12mm holddowns from HF, not a very good price tho.
            http://www.harborfreight.com/42-piec...kit-90752.html
              It's metric slots.
              You need 14 mm T-Nuts (with M12 thread). Shouldn't be too hard to find.
              Benta.
