I am a toolmaker during the day and I have a shop set up at home. I know I just can't get enough of cutting metal I guess. I am used to using rotary tables but this has me a little confused. I already own a six inch, I think phase 2, rotary table. It is 4 degrees per revolution or 90:1, which makes sense to me. I always wanted a 4" horizontal/vertical because the 6" seemed a little heavy for my benchmaster mill. So I found one at a flea market, and it looks to be new. What I don't understand are the graduations. It is 9 degrees per revolution or 40:1. OK still sounds right, a little coarse, but useable. But now this is wierd, the graduations on the handwheel show 4 degrees per revolution. I could kind of understand 4 1/2 degrees, I suppose. Nothing looks altered in any way, it just seems wrong. I have looked this over, counted the turns, figured I was nuts, checked it again and I get the same thing. I would really like to be wrong and have someone show me what I am missing. This rotary table looks similar to the one grizzly sells with indexing plates, they say that one is 72:1 though. Has anyone seen this before, or have any ideas? Thanks
4" rotary table
Ooh, Cadillac gauge in the second picture. I've got one that unfortunately sat outdoors on a pallet sometime during its life. Still scratching my head whether and how it could be restored sufficiently to be reliable. It turns smoothly but the step rings are rusty and they have to be really right. Maybe it's a moot point in the end. A 24" Cadillac gauge on a 12 x 18 surface plate would probably look about as useable as a V8 on a motor scooter..
From the last picture it does look like the dial goes from 0 to 50 four times. That would work with a 90:1 ratio.
For a 40:1 you need it to go from 0 to 50 nine times.
I'm guessing that the RT was available with two different ratios, and somehow the wrong dial got installed on this one. Seeing how the vernier marks line up with the dial might confirm this.
There have been several threads here about marking dials, so it might be worthwhile to make a sleeve with new markings to install over what's there.Any products mentioned in my posts have been endorsed by their manufacturer.
