I have a small TOS instrument lathe (3" x 12"). It is a metric machine with metric leadscrew. It uses change gears and I have a set of original change gears to allow me to cut metric threads from minute up to 3mm pitch. The change gears are MOD 1 and are made of steel. I would like to be able to single point cut the occasional imperial threads and for this I will require some additional change gears in the range of 56 to 72 teeth. Buying original TOS gears is difficult and expensive.
I was thinking that I could cut the gears out of delrin. I have the opportunity to buy cheaply a MOD 1 involute gear cutter which is for "135 and rack". I have the required dividing equipmet with the lathe. So my questions
1) Is delrin suitable?
2) I know that that this is not strictly correct, but if I use this cutter, will the gear teeth run together satisfactorily given that I can adjust the spacing on the quadrant and that it will be only for occasional use and I can take repeated light cuts?
You advice and opinions would be much appreciated.
Ian.
Ian.
