Had to try it.
  • Had to try it.
    I'm trying to post a picture here. If I succeed, you've created a photo bucket frankstein.
    It works.
    Is your name Frank Stein?
      It worked. Lets see more of that machine.
      rock~
        No, but the mill is 14 feet tall.
          rock~
          Yes, particularly the horizontal spindle setup.
            Yea its a nice picture but some guy got in the way of the nice looking mill.
            Can I get that mills number? Is she single? Does she have a twin sister?
              It's not working. Someone hacked the picture and superimposed an old geezer in front of the mill.
              Working good. Photobucket has gotten alot more use-friendly which in turn means more machine-porn!
              "The Administration does not support blowing up planets." --- Finally some SENSIBLE policy from the Gov!
                Why is the door behind the mill so much taller than the two in the corner?
                Is that the front of a 240Z to your right?
                  Rule number 1. No cars allowed in garages. Or is that your living room converted to your shop? Those doors look too nice for a garage.
                    That door is for the mill!!!
                    peter
                      There are wooden steps built up to the higher door.
                      Does that mill have a horizontal capability too?
                      VitŮŽria, Brazil
                        I want to know what happens if the two doors in the corner are opened at the same time.
                          Evan he would then have a diagonal hallway it looks like.
                          Also the door knobs are not at the same height on the corner doors. As a machinist you should rectify that situation before posting anymore pictures of your shop.
                            The high door goes into the house. The low door on the same wall is the garage entrance to the basement. The other door goes to the back yard. The two corner doors are hinged and spaced so they can open at the same time (it takes a little coordination). The wood working shop is in the basement.
                            Yes, the mill can be set with a horizontal configuration, but I don't have the end bracket yet.
                            As for the old geezer in front of the mill, I use this picture on all the dating web sights. Once women see that I'm a "Wells-Index Man" they're like putty in my hands.
                            The car is a 1972 MGB. I literally drove it until the wheels started coming off (axle actually).
                              We all know you are married by the large space in your garage that is not occupied by a 'in the process of restoration/modification car' or machinery.
                              Why have you not made an end bracket yet? All you need is a round toit.
                              So what are you waiting for? Go get a round toit
