If all goes well....new(to me) Rivett 1020S Saturday
  • #16
    That is a lathe well worth restoring. Contact kpotter on the PM site about what to do about the cross slide stop.
    I hope you can fix the lathe up. Those are not real common lathes,and are truly among the very best ever made.
    • #17
      Thanks for the compliments guys, I'm going to do my best to get this looking and running good.
      BTW, I just bought a china made quick change tool post for my Craftsman 10/12" lathe, the tool post on this is an Aloris, go figure!!
      • #18
        Wow a 1020S and a Wheel Horse. Life doesn't get much better than that.
        Jim H.
        • #19
          LOL A fellow "Horseaholic" ?
          • #20
            Dont have a Rivett, but got two WH's
            Nice lathe.
            • #21
              In some circles, 2 WH's are just as satisfying!!
              • #22
                How does the square rod work as a cross-slide stop?
                • #23
                  I think he means it is a carriage stop. My 1020F doest have one. I think Monarch 10EE owners call it an ELSR?
                  • #24
                    I'm not sure how the Rivett works, but on Monarch's lathe you can slide a stop up or down the rod to the position you want and the stop disengages the carriage travel.
                    Hal
                    • #25
                      There's a switch connected to the square rod, when it's pushed or pulled off center it stops the feed (I think the whole drive). I think the mechanism is electrical and the switch is in the tailstock module and if so the headstock (damaged) end can be fairly easily repaired. Brett on PM would know off hand, might ask him.
                      If it's mechanical and in the headstock end the repair could be painful. Worth it, but painful.
                      • #26
                        You are right, I ment carriage stop. You can see the broken collar here.
                        • #27
                          1981 C85. The deck is long gone, but it is my snow plow in the winter and faithful companion for yardwork in the summer.
                          Jim H.
                          • #28
                            Sorry did some photobucket moving and screwed up the pics. You can go here and see all I have;
                            http://smg.photobucket.com/albums/v2...ivett%20lathe/
