drills
  • drills
    was wondering what kind of drills you folks use for dting sst........i need to drill several holes......thanks Larry
    It depends...
    Quite a bit on which alloy of stainless steel you're drilling. You might get away with a regular drill bit but a cobalt bit would be a surer bet. You can get them a the Home Depot.
    Allans Rule: Anything worth doing is going to be a pain in the butt.
