Last night while reading through my old "American Machinist Handbook" By "Colvin and Stanley" -1926 -i came across an article about "When a file cuts Best."
Quote:
One who has given the matter carefull attention, and has built file testing machines, "Edward G. Herbert" of Manchester England, has come to the conclusion that a file does not cut best when it is new, but after it has been used for a time, say 2500 strokes or the filing away of one cubic inch of metal.
In cutting a file, the metal is forced up in a sort of a burr, and occaisionally the top of the tooth slopes over backward which is the reasonthat a file often cuts better after these are broken or worn off. Too the teeth are not all the same height, and only a few points cut. As they wear down, more teeth come into contact and do more work.
Opinions IF this applies to todays files??
