SFM calculating
  • SFM calculating
    Fellow machinists: my students and I are doing an experiment we are going to find as many different formulas for calculating spindle speed as we can then graph the results...we want to test to see which is the closest and to see how many there are
    Currently I use RPM = SFM x 4 รท diameter...
    What do you use?
    Thanks!!!
    what?
      I use that too, have for 65 years. Peter
        Well, the actual formula for translating between RPM and SFM with the diameter (d) being measured in inches is:
        RPM = (12 x SFM) / (3.141 x d)
        This simplifies to:
        RPM = 3.820 x SFM / d
        The 4 in the often quoted equation as you have stated is actually an approximation of 12 / 3.141 which actually equals 3.820. The error is only 4.72% so it is good enough for most shop purposes and a lot easier to remember and use. I doubt that most motors used on our machines are that accurate.
        Make it fit.
          You either get one formula (the exact right one) or multiple approximations, which usually are close enough for anything.
          ..so, what is the point of this?
            That is what I was taught to use CS x 4/ D where CS is the cutting speed in Feet Per Minute and D is the Diameter of the Workpiece or Cutter, whichever applies.
            Will
              Some of you grumpy old farts have forgotten what it was all about when you were a student. The point for a student is what you learn on the journey, not what you see when you get there.
              It seems like a practical exercise in understanding the relationship between rpm and surface speed, or maybe even more fundamental, the relationship between diameter and circumference.
              Phil
                RPM = sfm( M/s ) x 320 / cutter dia in mm
                note this is for metric cutters
                  Marty,
                  Did you explain to your students the meaning (or geometric meaning with some arithmetics, if you will) of the formula you gave them? May be then the absurdity of the project will become more apparent.
                  I'm sure you realize that "4" in your formula is really 12 (as in inches per foot) divided by pi, don't you?
                  WI/IL border, USA
                    Phil
                    You nailed Phil! Students get frustrated when there is more than one way to skin a cat!
                      I use my sight and sound to judge sfm.
                        I used to do that too until I discovered my tool wear rate was way out of line. Having no talent for that, I bought a laser tachometer
                        Marty's formula is the one I use, too, but pretty much was self-discovered after a few sessions with the calculator.
                          blackadder, its 318, right? (i mean, 300 is easier.)
                            http://www.monstertool.com/monster_t...lculators.html
                            jack
                              its 320 as in my post I know I am dyslectic but you made me check my post
                              eg 320 x 24 /12
                              give you 640 rpm for a 12 mm cutter in steel ( en1a )
                              but in practice I use a machinist pro calculator ;-) expensive but they do so much more
                              Stuart
