spiral bevel worm gear
  • spiral bevel worm gear
    this is the first time I've seen one like this.
    http://www.youtube.com/watch?v=F-Dvw...endscreen&NR=1
    I am fairly certain it is a hypoid, like in most automotive differentials.
      I imagine it is- I've just never seen one with that high of a ratio.
        Not only a Hypoid but an Offset Hypoid.
        When we built rear ends at work I was always amazed that the pinions being cut on the Gleason's despite being held with a center in the gear end and a collet (around .750 IIRC) on the drive shaft end of the part would never once squeal or make any other noise. Just the faintly heard sound of the chips coming off of the part and hitting the collection pans. IMO Gleason's are the single most logically designed machine tool I have ever seen. If the was a problem in one are of the machine simply by removing a number of screws and 2 or more dowel pins a whole section of the machine could be slid right out.
          Let me display some ignorance here, what is it that makes it an "offset hypoid"? As opposed to just hypoid?
          I did notice, it looks like the pinion has two teeth, or is it two start?
