Tool gloat...
  • Tool gloat...
    Small little tool gloat..
    A Rockwell 1" belt sander...model is 31-352.. with a nice 1/2 hp capacitor start baldor motor....
    Cost...$45
    Its well used I think, but motor runs smoothly. Wonder how easy it would be to convert to a 2x72.....
    Good find for only $45.00!!
    (Don't you find it hard to use though on it's side?)
      I tried flipping the pics..to no avail...
        You or someone else suceeded!!
          has to be me... cause I got the darn thing for $45...
          What is funny, wife goes... "oh, thats not so bad" What till I need "parts"
            Nice find, we've got some of those at work, they're decent machines.
              What's that car doing in the garage, taking up all that good space.
              That's no place for a car. Or do you have a shop somewhere else.
              VitŮŽria, Brazil
                Nice find. I have a later model of a very similar sander made by Delta. Also has the disc.
                The vertical arm looks a little bent as if it was about to buckle.
                -DU-
                  yes.. its a bit out of kilter I think.. my initial thought was to replace the arm to make room for a 2 x 72 belt..
                    Very handy machines, I have two.
                    Original parts can be a problem, as in not available anymore, you can make new rollers. The main bearing of the driving wheel goes bad, but you can jury-rig something there too.
                    Is that one Rockwell? Or a clone? It doesn't look quite like mine (from memory).
                      Its a Rockwell...31-352
                        It's a Rockwell, but it looks like someone replaced the motor with a Baldor, which is a good thing. It looks like it's been painted -- both of mine are dark grey.
                        I have two. One, like Rob's, uses a separate induction motor. The newer (still made in USA) model uses a universal motor. OMG, that sucker is LOUD!
