y'all were right
  • y'all were right
    Thanks to all who gave such encouragement when I got the new machine shop. I have been in it now for four months and I am having a great time. The forge/foundry is not finished yet (not a high priority since we have two smithys already) but the woodshop is in and working, albeit in rough form.
    I have certainly found much to do! Outside of tramming/tuning/dailing machines, there is much to repair/rebuild.
    Most current project is a run of engraver's tables to be used in upcoming classes.
    And now a question:
    We are making some small hinges for decorative boxes, and would like to machine the leaves to recieve the barrels. The barrels are end-drilled 3/8" rod, and are brazed on the end of the 14 gauge leaves. I would like to make a 1' section of 14g. (3/4" wide strip) that has an 1/8" radius on one edge at 20 degrees. In other words, a 20 dg bevel, the "bevel" being an 1/8" radius.
    Any ideas on how to hold a 1'long 3/4" wide strip of 14 g. at 70 dgs for milling? I am all set to make a vise, and would like to know if there is something obvious I am missing....
    Michael (who is certainly no machinist, but did finally figure out how to change the cutter in his horizontal mill)
    Hammer In Hand
    Does it need to be milled?
    Won't running it over a belt grinder do?
    You can also draw file it.
    Sometimes its faster and easier to do something by hand than to set up a machine. Especially if precision is not essential.
    These are decorative hinges, right?
      yf,
      Nope plain ol' hinges. Check out my site at http://www.hammerinhand.com It will explain more than I can.
      Draw filing would leave a flat, that is how I am making them now. Belt sander would be the same. The intention is to get them fitted, thus the radius.
      I have made several floats, and thought about just making a 1/8" curved one, but then I bought this machine shop and etc...
      Hammer In Hand
        Stand it up in the vise, sandwiched between two 12" pieces of heavier stock to beef it up, if you have a six inch vise you will have 3.00" overhang each side. Pick up the high side face & set zero, using a .250" dia ball end mill offset .078" towards the low side, mill your .125" radius, which will be 20 deg across the edges.
        Les H.
        Les H.
        The Impossible Takes Just A Little Bit Longer!
          thanks Les!
          Was thinking about using the horitzontal mill but this sounds easier. I will give it a try!
          Hammer In Hand
