OT: computer password problem
  • OT: computer password problem
    Today my computer decided to not accept my windows user password. I tried rebooting several times. I took the battery out of the motherboard to try and reset the cmos. I went online to look for a solution but didn't find one that worked.
    So anyone have anything they would share with me as to what I can do to get access to my files on my C drive?
    Make sure Caps Lock is off and Num Lock is on.
    If that fails, use this: http://pogostick.net/~pnh/ntpasswd/
      At a friends computer, install a Linux on a USB stick and boot your computer from that. Then you are able to browse your hard drive and copy everything you need, just in case.
      Other option is to remove the hard drive and install it in another computer as a slave drive and access it that way.
      No passwords required, unless you have encrypted drive.
        Probably overloaded it with Volvo pics!
          Log on as USER: Administrator, and leave the password blank, since that is the default for windows.
          Monarch 10EE 1942
            If it's a personal computer and only used by you then it serves you right for ever using a password. :-) The fewer things that get put
            on a computer the fewer things to go wrong. :-)
            ...Lew...
              doesn't apply to a desktop but on a LT make sure num lock is OFF!
              Make SURE your username is correct
              Try another keyboard. and / or watch to see if each keypress causes ONE new dot. As a quick check try entering your password as a user name to view the keyboard output
              if a USB keyboard, try a different port. Note that windows may take a few minutes to find keyboard on a different port
              I like to use a password even if I am the only one on the machine. and Administrator should NEVER have a blank password. On Vista and above the administrator account doesn't exist by default
              there are Linux boot cd's that can be used to reset the windows password; or as a previous poster mentioned you can copy files IF YOU DID NOT SPECIFY AN ENCRYPTED FILE SYSTEM
                Bootable Linux
                As has already been mentioned, use a bootable cd/dvd to change the admin password. The ISO will be about 10MB and the entire change process will take about 60sec (if that).
                Of course, if it's the only computer you have, the burning process will be a little complicated...
                  Hey Lew, did anyone ever tell you that you are a ؤhole! Well now they have! I don't wish you any serious harm but being constipated for a week would seem justified.
                  There are many reasons to have a password on a sole user personal computer.
                    I got it fixed. I ran a linux based registry editor and removed the password. Thank you for your help.
                      Many reasons to have that password for sure, but the solution to your problem once again showed how easy it is to bypass the said password
                        Locks or passwords only keep honest people honest. I don't have them on there for the bad guys. They will get in no matter what probably.
                        I have five computers networked together at my home. Some of the password protection is to keep files from being altered unwitingly by memebers of my family.
