What type of steel
  • What type of steel
    Does anyone know what type of steel is used when they make tapered sleeves for the spindles on lathes?? Is it harded? Thankyou.
    If you are referring to Morse taper sleeves, they may be hardened, or not depending on intended use.
    For the normal, light use in a home shop, hardening would not be necessary.
    Jim H.
