Metric Threads
  • Metric Threads
    Ok so i have only just started cutting threads on my lathe and I am looking for some advise. I know all about how to use the thread dial indicator to cut inch threads but i have read that you cannot use it for metric threads Can someone explain this for me?
    It's going to depend on your lathe, but most standard leadscrew lathes can cut metric with a proper change gear (most I see are 127 tooth instead of 120 for standard) and the rough part is once the half nuts are engaged.....they need to stay there. If threading into a blind hole, it is near impossible unless the tool goes to the back side and upside-down which allows cutting from the blind out, and reduces the crash risk.
      If I understand correctly, you can use the thread dial indicator to cut metric threads on a lathe that has a metric leadscrew but even then you may have to change the pinion on the thread dial indicator for different metric threads.
        A 127 tooth gear is standard on most inch and metric lathes for inch>metric and metric>inch leadscrew conversions.
        There are 25.4mm in 1 inch.
        5 x 25.4 = 127 (teeth).
        If cutting a thread in a "blind" hole you will need a "relief/clearance" groove say two threads wide and you can use either method.
        Some lathes cannot fit the tool on the far side of the cross-slids so in that case its best to have the tool inverted on the near side (front) of the cross-slide and run the lathe to cut in reverse when cutting the thread.
        If cutting a metric thread on an inch lathe as well as an inch thread on a metric lathe the clasp nuts must remain engaged the whole time.
        In both cases on both types of lathe the threading dial is of no use.
          True. My metric lathe has a 3mm pitch lead-screw and a 72 tooth pinion which does work quite well but is limited - so I, like many who cut inch threads on a metric lathe leave the half nuts engaged as it is nowhere near as straight forward as screwing inch threads on an inch lathe.
          http://i200.photobucket.com/albums/a...d-cutting7.jpg
          http://i200.photobucket.com/albums/a...d-cutting8.jpg
          http://i200.photobucket.com/albums/a...d-cutting9.jpg
          http://i200.photobucket.com/albums/a...-cutting10.jpg
            Nah, you just need skill...
            135mm X 2mm thread cut to a shoulder @ 110RPM, lathe has imperial lead screw..... Just needs practice to do...
            Precision takes time.
              is that a carbide tool? do you take it out of the cut before stopping the lathe?
                Yea carbide as for moving the tool out, you move it out of the cut, cut the power and hit the foot brake at the same time... It just takes practice to do.. I actually like cutting threads on the lathe...
                  Thread cutting is fun
                  Hi guys,
                  Like .RC., I also quite like cutting threads on the lathe. Good thing too, as I've had quite a few to do lately.
                  While most of my thread cutting is imperial, I've also done a few metric threads on my lathe with an imperial lead screw, and I do dis-engage the half nuts.
                  I can't find my notes atm, so writing this from memory...
                  Set up the lathe to cut your thread as required. Choose a number on the thread dial, and stick to it. I'll use "1" as an example.
                  Engage the half nuts when "1" comes around, and make your first pass. When you get to the end of your thread wind out (for external threads)
                  the cross slide and dis-engage the half nuts. Now stop your lathe. It's important that you stop the lathe before the thread dial makes a complete revolution.
                  Now, and this is the clever bit, reverse your lathe and watch the thread dial. When your number, "1" in this case, lines up with the pointer, engage
                  the half nuts and let the lathe drag the tool back the the start position. Don't disengage the half nuts when you get back to the start position.
                  Return the cross slide to the previous position and put on your next cut depth as per the threading method you are using.
                  Repeat as before until your thread is done.
                  Because you are engaging the half nuts on the same number in reverse you are effectively engaging the lead screw at the same point you dis-engaged it.
                  I've done quite a few metric threads this way, at reasonable speeds, 200-300 rpm, and haven't stuffed one up yet.
                  Hope that helps.
                  Best regards
                  Mark
                    It's best if you operate the clasp nut lever with the cheeks of your arse. Believe me they are the fastest acting muscles in a human body.
                      I had to cut some metric threads with my atlas not long ago. I wired up my motor to reverse so I could leave the nuts engaged. Worked great!
                        ...but retract the tool first, or you'll trash the thread on the back-wind.
                          Unless you use one of those flip up tool designs that was posted on here some while ago.
                          That's all I use now for threading, never use the dial on metric or imperial any more, in fact I have removed it so it doesn't get in the way.
                          In fact on the way back I'm putting the next cut on.
                            Originally posted by MarkA
                            Hi guys,
                            Hope that helps.
                            Best regards
                            Mark
                            I have been meaning to try that, but always pussed out. Thanks for the tip.
                              I thought if you had a thread dial that had 1-2-3-4 and an english lead screw you could use 1 or 3 for odd threads and 2 or 4 for even threads in english. But for metric you needed 1 and could not use the 3 .
                              But mine has 1-2-3-4-5-6 and I just use the number listed on the thread chart from the manuafacturer. So I always use what is on the chart and it seems to work fine. I do disengage on each pass, metric or english
