Using up every last bit of scrap
  • Using up every last bit of scrap
    My 3/8" black Delrin rod was down to the last inch but I decided to try to get one last part out of it.
    I got it straight in the chuck by offering it up chucked in the tail stock.
    Barely hanging on
    Machining complete on one end
    Finished part
    It never moved during turning, drilling through, and counterboring in spite of the fact that it's a slippery material.
    That's a #8-32 screw for scale.
    "by offering it up chucked in the tail stock."
    what do you mean by that?
    besides, weird delrin, how come its black?
      Delrin is available neutral or black, check McMaster Carr, they have lots of it. We always buy black for prototype parts. Bob.
        I believe to get it chucked straight(ish), he first put it in the tailstock drill chuck, then tightened down the headstock chuck. It's a handy trick when you're using the last little bit of something, or if you're working with a pocketbook hurting material and want as little waste as possible.
          Sometimes I've done similar "savings", but turned it between centers as the part would have a hole through it anyway
            It comes dyed many colours, I prefer black but the local supplier seems to have only natural.
              You probably have a 'real' lathe.
              There's no room for me to get the cutter in if I've got the tail stock in close.
                Yes, that's what I did.
                I invented the technique but decided not to make a big deal of it, you guys can use it if you like, just don't share it with those PM guys.
                  Done that with a SIEG SC4 and at work with two big machines. Just needs the tool extended a little bit further out for small diameters and a narrow nosed center.
                    Just curious but wouldn't delrin make decent supports for a steady rest? As a replacement for the brass/bronze fingers? Thanks, Frank
                      I don't think they would take the heat and friction for very long
                      Tom C
                      ... nice weather eh?
                        Friction will soon melt them down and anything not-ground will eat them up pretty soon and badly.
                        But for some sensitive/delicate/light work and with a lubricant they might work.
                          I have a travelling steady that was supplied with my c1907 Drummond lathe which had wooden inserts instead of fingers.
                            Wooden? I hope that were either Ebony or Lignum Vitae. :-)
                            ...Lew...
                              ...Lew...
                              I think it was a block of whatever was available. Presumably one was expected to mount a block in the holder (two blocks actually) and drill a hole through to match the diameter of the work. No doubt it worked quite well.
