Hi all
In 1969 had basic machine shop training for 2 years, lathe, casting, gas welding, sheet metal, spot welding, tool making, and rod iron bending, and tempering steel.
Not a lot of time on lathe the last lathe test was making a ball bearing by hand.
After reading May/June 2012 the home shop machinist cutting speed and feed rates figure 2 pages 58 you see a wave in the cutting.
Do you get this from manual by hand feeding? and would you get this from a flat cutting tool.
