i "binged" the phrase, got a cople of hits that said to start with oven cleaner.. well, thats sounds pretty much ok except for the scrubbing part. . .
this is a webber propane grille, cast aluminum body and cover, and a removable sheet metal underneath..
ive replaced all the steel crossbars above the three burners and the gratesare nearly new, at least they still have enamel or porclen (sp) on them but the main body inside and out is all white and cruddy looking.
hi temp paint will cover it after its a bunch cleaner but what else have any of you guys tried for cleaning. . . this thing was fairly spendy when it was new and throwing away is not an option.
best to ask the masses before forging ahead with an unknown.
